#1 Posted : Friday, 11 May 2007 7:40:52 AM(UTC)
Hi all, i am wondering when should do you change your diff oil, no info in my gregories manual about it at all, my car is 10 years old, and its never been changed.
thanks in advance for any advise
#2 Posted : Friday, 11 May 2007 9:18:15 AM(UTC)
Generally, diff oil is only changed at overhaul time or if you have a bad enough leak that you need to top it up.
Cheers...Dave
#3 Posted : Friday, 11 May 2007 9:31:50 AM(UTC)
Thanks for your reply Dave, iv'e got no leaks at all but just wondering why all other oils get changed but you never hear anything about changing the diff oil.
Thanks... Greg
#4 Posted : Friday, 11 May 2007 9:53:07 AM(UTC)
Gearboxes, generally, are the same, at least the old(er) ones. I'm not sure about the new ones where manual boxes run auto trans fluid...
Cheers...Dave
