rileyp Offline
#1 Posted : Friday, 11 May 2007 8:44:44 AM(UTC)
rileyp
Im now the proud owner of a vp commodore although the p/s seems to make glug (as in fluid movement) noises when I turn the wheel a few times while parking etc..(or is this the ac or heater???
Any idea what this would be?
Also it has worn out p205/65/15 tyres
I have some very good 185/70/14's Could I use these?
as on the tyre placard it suggest 185/75/14's
Although it does suggest a different rim...
How can we speed up the fastlane server?
I havent been on fastlane in so long I forget my username!...over 3 or 4 years...
rileyp Offline
#2 Posted : Friday, 11 May 2007 8:46:26 AM(UTC)
rileyp
Oh i forgot to mention it has 130k on the clock
rileyp Offline
#3 Posted : Friday, 11 May 2007 8:50:00 AM(UTC)
rileyp
and here she is!
#4 Posted : Monday, 14 May 2007 11:10:29 PM(UTC)
Looks good. To change to 14" tyres obviously you need 14" wheels from a VB-VP series 1 Commodore not hard to find as they made 1000's of them.
The 14" wheels won't fit if you have the larger (V8 type) of front brake calipers which became standard on
rileyp Offline
#5 Posted : Tuesday, 15 May 2007 6:57:28 AM(UTC)
rileyp
I have bought some 205/15's now so ill just sell my other tyres I spose
It was made in feb 2003?
does this help
How do I tell if its series 1 or 2?
#6 Posted : Tuesday, 15 May 2007 8:09:53 PM(UTC)
Series 1 has 14" wheels standard but 15" wheels were optional they also had an semi clear grille.
Series 2 has 15" wheels standard a body coloured grille & a small series II badge on the back. I have also seen series 2's with an indentation in the cons
#7 Posted : Tuesday, 15 May 2007 8:17:57 PM(UTC)
To stop the glugging you could try bleeding the power steering. Easily done in a few minutes. Just jack up the front of the car so that both front wheels are off the ground. Place stands under the car if you care about safety. Then start the engine & turn
Edited by user Tuesday, 15 May 2007 8:22:16 PM(UTC)  | Reason: Not specified
rileyp Offline
#8 Posted : Thursday, 17 May 2007 4:24:30 AM(UTC)
rileyp
Ahah!
I had to get the front discs machined for rwc and while i had it up on the stands i started the car and turned the steering wheel to full right lock then left lock a few times to see if would do anything strange as I was a bit concerned about this
rileyp Offline
#9 Posted : Thursday, 17 May 2007 4:26:30 AM(UTC)
rileyp
Thanks for your help fellas!
rileyp Offline
#10 Posted : Thursday, 17 May 2007 4:31:17 AM(UTC)
rileyp
Oh and the is a series 2 badge on the tailgate
Im emabarressed now.
#11 Posted : Wednesday, 13 June 2007 8:50:40 AM(UTC)
its still making glug glug glug noises... any ideas???
