#1 Posted : Friday, 18 May 2007 3:25:47 AM(UTC)
im chasing the id of a 4 speed, number on casing is T953359. number stamped on back of casing and extension housing is 1569 R P. lay gear is 2813497. is there any websites with ID numbers.
Thanks peter.
#2 Posted : Friday, 18 May 2007 4:15:47 AM(UTC)
My website www.monaroparts.com lists most aussie 4 speed stuff.
That cluster gear is M21, V8 or 6cyl. You'd be very lucky to find a 6cyl one though.
If we all had the same (good) taste, who woul
#3 Posted : Sunday, 20 May 2007 8:50:18 AM(UTC)
Thanks Byron, I striped the box today and found the cluster gear chewed out on one end. can they be repaired or is it best to replace? any idea on cost. And a good place in brisbane to do this
peter
