#1 Posted : Saturday, 19 May 2007 12:32:51 AM(UTC)
Hey Guy's, hoping someone can shed some light on this issue for me. I have just purchased an 73 GTR Torana and have be told two different stories when it comes to adding lead to the fuel. A bloke at Auto Pro has said not to use it as it will clog up the valves and I should just use premium unleaded. Another bloke who owns an old Ducati has told me that I should use it but at only half the recommended amount per litre. Does anyone have any more info as I do not wish to do any harm to the engine.
Thanks Benno...
#2 Posted : Saturday, 19 May 2007 12:38:14 AM(UTC)
Call an LPG Conversion specialist...
ask them about it, or who to speak to if they cant help you?
i think from memory, as long as it has alloy heads and hardened valves, or something?!
not sure?!
hope that helps?!
Mark.
BrianH Offline
#3 Posted : Saturday, 19 May 2007 5:43:16 AM(UTC)
BrianH
Benno
Look up any of the oil company web sites and ring their technical advice section. If they don't know then nobody will.
Brian
peter_flane Offline
#4 Posted : Saturday, 19 May 2007 6:06:25 AM(UTC)
peter_flane
Just use premium unleaded and add some upper cylinder head lubricant (UCHL). Morey's, Nulon, whatever brand floats your boat. It's not rocket science. In fact rocket science would have fuel calculations. Yeah?
Anyway you wont instantly blow up or seize
trubluhq Offline
#5 Posted : Sunday, 20 May 2007 3:10:40 AM(UTC)
trubluhq
Can the GTR head take modern guides and valve seats ?? That would alleviate the need to worry about additives. Cant be seen either so wont effect originality. I had a 1942 cast iron side valve block done...worked a treat. Should be a snap on the GTR.
C
#6 Posted : Sunday, 20 May 2007 8:45:10 PM(UTC)
Yes you can fit modern guides and seats in the red heads John.Benno as Peter said running UCLH works fine and I have run my HQ and my HR on straight unleaded for years with out any problems.But if you want the facts on if they do still burn valves on unle
trubluhq Offline
#7 Posted : Monday, 21 May 2007 2:13:36 AM(UTC)
trubluhq
Yes HQSS...I run Premium in the HQs too, no additive. the 235's wont rev hard enough to warrant it. Barely 2000rpm at 100kmh.
Cheers John
#8 Posted : Wednesday, 23 May 2007 10:18:02 PM(UTC)
Thanks alot guy's. On reading all your replies and speaking with a few other people I think I'll stick with premium and the UHCL and then go over it closely when we do the next rebuild. Cheer's.
Guest (5)
