wimjack Offline
#1 Posted : Saturday, 23 June 2007 2:42:08 AM(UTC)
wimjack
Hi
Does any one know if the disc brakes off a Borgwarner Diff fit on a drum brake 9 inch Diff, as I want to convert a 9in to discs.
Cheers Jack
#2 Posted : Tuesday, 26 June 2007 1:40:03 AM(UTC)
I believe that you can do it if you use the brakes from an XF onwards diff. These have a separate "backing plate" type of caliper mount.
you will still have to replace your rear seals to suit the thicker "backing plate" if your diff is XA onwards wi
