#1 Posted : Sunday, 24 June 2007 8:27:57 AM(UTC)
polyurethane, nolathane and ulethane. Just wondering what is the difference between the three and are they a better replacement for rubber? Longer lasting etc. Are you better off to mix and match (rubber and a...thane) to certain areas? I have heard they have become a lot softer now and are available in different hardnesses? Any info on this subject matter would be greatly appreciated. Have had differing opinions? And would like to learn more.
ozchevy Offline
#2 Posted : Monday, 25 June 2007 7:43:31 AM(UTC)
ozchevy
Hi Sandman,
Polyurethane and Nolathane are two of the same.
Nolathane been a Tradename.
This stuff is pretty expensive to buy as off the shelf suspension components.
I went the other way last year, and bought a 1 metre rod of urethane and machined u
#3 Posted : Tuesday, 26 June 2007 4:39:40 PM(UTC)
Thanks for the info. Thats a good suggestion and a different way to do it. Maybe a bit hard for me to myself tho.
hainzy Offline
#4 Posted : Tuesday, 31 July 2007 5:56:45 AM(UTC)
hainzy
Hi guys. Just to revisit this thread.... What do people think is the best option? I also have a 308 HZ sandman, will be getting slightly lowered, and used for round town and highway drivin. Nothin too crazy. I have my swaybar out at the moment and the bus
Mr.Jones Offline
#5 Posted : Tuesday, 31 July 2007 8:01:51 AM(UTC)
Mr.Jones
my 2c worth, I went with rubber bushes for all suspension arms and chassis. Nolathane for swaybars and radiator support and also rear spring insulator. I drive a combination of around town and less than smooth highway and the odd dirt road, so I didnt wan
Voltaire
ozchevy Offline
#6 Posted : Tuesday, 31 July 2007 1:42:25 PM(UTC)
ozchevy
Yes Leroy, they do become noisy if not well lubed, and the best lubrication - although expensive is Teflon grease. The only advantage in using Teflon lubrication is, not too much need be applied, as it lasts for seemingly ever. As will your Urethane bushe
