#1 Posted : Wednesday, 27 June 2007 2:40:11 AM(UTC)
Hey guys,
I'm having some trouble with my a/c and heater control assembly it would appear. The temperature sliding button works fine however the 'mode' labelled slider doesn't work properly at all. When you switch it so the air comes out at your feet it works fine, then if you try to switch it to come out of the vents near your face it no longer works. I check the relays and fuses they are fine, I pulled off most of the bezel and I found that the small pumps which close off and open the air way arn't working. The fan speed button is also playing up so i'm assuming I'd need to replace the control assembly but I'd like to make sure it's that and nothing else and any numbers of places which are wrecking commodores because I kno very few. Anywhere close to Narre Warren would be good, that's in south eastern suburbs of Melbourne.
