#1 Posted : Saturday, 2 June 2007 4:09:55 AM(UTC)
i need help with this ute its a 253 hz 78 now i have given the engine a clean up with degreeser now it sounds like its running on 6/7 cylinders so i replaced plugs and leads but still missing any1 with some idea as 2 what i may have wet when i washed off degreeser as it was running fine before i cleaned it up all info be great
hz dude Offline
#2 Posted : Saturday, 2 June 2007 5:30:13 AM(UTC)
hz dude
try taking the dizzy cap off and wipe that out make sure it's dry .check the points if you have them otherwise make sure the dizzy is nice and dry that will cause alot of miss fire problems good luck but make sure the dizzy is dry!!!!!
#3 Posted : Saturday, 2 June 2007 5:39:48 PM(UTC)
thanks hz dude i have done this and the dizzy cap looks very worn so gunna buy new rotta button and cap ???
#4 Posted : Tuesday, 5 June 2007 12:24:44 AM(UTC)
bought new dizzy cap and rotta button spot on again thanks
Guest (5)
