1tun Offline
#1 Posted : Saturday, 2 June 2007 8:58:50 PM(UTC)
1tun
Hi fellas,just putting a gilmer drive on my lh torry,the water pump pulley hits the water pump without the bolts in it.Is there suppose to be a spacer for it or can u buy a water pump with a longer housing?Any help much appreciated.
#2 Posted : Saturday, 2 June 2007 11:08:36 PM(UTC)
Good,you have the old school one. i dont know if its a good idea but i used a little tiny bit of blu-tak on 4 even size washers for that. i have done almost 15000 kms like that with no trouble. but the WB-VS water pump is 12mm longer but the front edge of
1tun Offline
#3 Posted : Sunday, 3 June 2007 4:53:26 PM(UTC)
1tun
even with washes behind the water pump pulley i can only get the water pump pulley and alt pulley to line up.The crank pulley with spacer sticks out to far and without spacer its not out far enough.I have nearly given up on the belt drive bummer
