HarryO Offline
#1 Posted : Sunday, 3 June 2007 11:18:58 PM(UTC)
HarryO
Hoping someone can help with refitting starter motor solenoid connectors.
It is a 186 in an EJ, but I imagine as it is a Bosch, these have been used for countless models!
I have 3 wires to connect- main cable from battery, red wire & a deep purple wire.
Holden factory manual lists the main battery cable & red fuse-board wires on one solenoid terminal post, and purple to the ignition switch to another post?
But unfortunately I simply marked both red & purple as ‘starter’, and forget which went to which solenoid terminal!
Can anyone confirm which wire fits to which terminal (see crude diagram):
(one terminal has the copper wire running to the motor)
Thanks for any help (new motor in, all wiring done, just need this last bit to crank her over!!)
HarryO
#2 Posted : Monday, 4 June 2007 3:11:10 AM(UTC)
Hi HarryO.
What you haven't shown in your diagram is the 3rd (small) terminal. It is located at 6 o'clock on your diagram, if we accept that the 2 thick studs are at 3 o'clock & 9 o'clock (hope you can understand that).
Nothing except the existing b
HarryO Offline
#3 Posted : Monday, 4 June 2007 4:20:02 AM(UTC)
HarryO
Cheers. I forged ahead & fitted red & main to the 3 o'clock. Electrics came to life with no issues. Tried the purple to 9 o'clock, earthed, and so-forth. No response. It is a small fork connection, which wouldn't fit these. Thank you. Off to start the old
HarryO Offline
#4 Posted : Monday, 4 June 2007 4:25:58 AM(UTC)
HarryO
Bugger. There is no connection at 6 o'clock :(
#5 Posted : Monday, 4 June 2007 5:50:52 PM(UTC)
If the last terminal is there it could be bent backwards like the one in this image HarryO, it is a simple push on terminal.
I haven't got any better photos than that in the work guides
#6 Posted : Monday, 4 June 2007 6:54:25 PM(UTC)
Hi HarryO.
Are you using the EJ starter or one off a 186. If you're using the EJ starter, the terminal is no more than just a screw that might be screwed up tight, so it just looks like part of the assembly of the cap & not an electrical connection. Th
HarryO Offline
#7 Posted : Tuesday, 5 June 2007 5:55:54 AM(UTC)
HarryO
Thank you guys. Appears manifold & exhaust is coming back off...
Unfortunately I cannot see the bottom of the solenoid from any angle, thanks to the damn extractors. There is certainly no spade showing. all I can 'feel' is a protruding bump much more p
#8 Posted : Tuesday, 5 June 2007 9:07:52 AM(UTC)
Hey HarryO try to find a small mirror to get a better look underneath before taking it all back off. Also, if you have extractors I recommend investing in the smaller later model starter motor, they're hi-torque so will start the car better and you can ac
HarryO Offline
#9 Posted : Tuesday, 5 June 2007 5:27:31 PM(UTC)
HarryO
Cheers Reaper for the idea. Mirror worked a treat. Sure enough, there is a screw hole at the very bottom. Back in business!!! Thanks a bunch.
#10 Posted : Tuesday, 5 June 2007 7:27:23 PM(UTC)
Good stuff HarryO, much easier than dropping the extractors and manifold back off I bet! For interests sake here is the image to the hi-torque compared to original starter motor I mentioned above, these are a terrific starter motor and you can't go past t
jabba Offline
#11 Posted : Tuesday, 5 June 2007 11:45:53 PM(UTC)
jabba
And there is another trick from the chevs which may help with hot starting (especially if you do not have a great deal of clearance (clarence).
Get a remote mount starter solenoid (even some POS jappa one from supercheap or somewhere similar) and mount
Edited by user Tuesday, 5 June 2007 11:46:47 PM(UTC)  | Reason: Not specified
Guest (13)
