#1 Posted : Thursday, 2 September 2004 9:38:57 AM(UTC)
Ok a simple question, with no real answer in ALL my manuals.
HOW TO GET THE ARMS OFF !!!!
I can see a springy thing near the drive shaft, which doesnt do much. Probably seized on right ? Am I warm ? Surely they dont just pull off.
Whats the secret ?
Cheers John
#2 Posted : Thursday, 2 September 2004 4:49:01 PM(UTC)
Yep! They just pull of. Some of them have a little clip that hooks under spline so make sure you slide it sideways a bit. I then use a large screwdriver and lever them up using my left hand as a fulcrum on the bonnet with a few rags under. It is a good id
#3 Posted : Thursday, 2 September 2004 6:23:52 PM(UTC)
SH*T I was afraid of that !!!!
TA.....John
#4 Posted : Thursday, 2 September 2004 9:18:40 PM(UTC)
yes thought as much...press the tiny spring at the spline end, lots of wd40, and while pushing the spring outward, pull off the arm.....easy....phew.
Cheers J
This page was generated in 0.091 seconds.
