jabba Offline
#1 Posted : Friday, 29 June 2007 4:25:06 PM(UTC)
jabba
I seem to recall a discussion on this, but can't track it down.
I have just acquired an HJ Monaro GTS Sedan (back in the game - wahoo). It is tidy, but not immaculate, but a very good driver / project vehicle.
One of the things that I do want to get sorted failry soon is the seat recliner mechanism on the driver's seat. It seems to be loose / broken on the left hand side. It falls back, but grabbing it and pulling forward it clunks and clanks and stays forward for a while.
The bolts and plates on the side seem firm, so where to from here?
j
#2 Posted : Friday, 29 June 2007 4:31:01 PM(UTC)
Grab any HJ to HZ bucket seat and remove the reclining machanism, not a hard job, and put it onto yur seat. If your seat needs retrimming I would just put the other seat in.
Warren
mmazz30 Offline
#3 Posted : Friday, 29 June 2007 8:01:39 PM(UTC)
mmazz30
Jabba make sure you have a 1/2 socket that fits in the hole where the bolts are.When you attempt to pull the plastic covers off,you break the clips that press into the metal.File/machine/grind down the socket to fit in.
While i'm here does anyone have
