rust and grease Offline
#1 Posted : Monday, 2 July 2007 9:47:53 PM(UTC)
rust and grease
Hoping somebody might give me some advice....my 186 long motor is lying on its left side without oil on a couple of old wheels and tyres waiting for a new sump gasket.
Because of shortage of free time its been sitting like that for several weeks and somebody has said that the hydraulic lifters will run out of oil and that it will be very difficult(and damaging)to build up oil pressure when the motor is restarted. Is this the case and is there anything I can do now to fix it?
Thanks for any replies.
Mr Void Offline
#2 Posted : Tuesday, 3 July 2007 3:07:45 AM(UTC)
Mr Void
what about new motors? I don't know the answer to your question but it only takes a few seconds for a fresh motor to build oil pressure... I would have thought it would be ok for that amount of time??
Anyone?
___________________
Why are you readin
___________________
aitken_321 Offline
#3 Posted : Tuesday, 3 July 2007 6:58:52 AM(UTC)
aitken_321
Should be alright might not run vary good until get oil up to the lifters but should be right once dose.
hz dude Offline
#4 Posted : Tuesday, 3 July 2007 8:40:40 AM(UTC)
hz dude
cold crank with the motor in the car or on a trolley but no rotor button .so no spark so no start this stops the sudden kneed for oil when its not there (damage)crank for a little while then give it some spark then see how you go thats the best way to do
This page was generated in 0.120 seconds.
