#1 Posted : Tuesday, 3 July 2007 1:05:37 AM(UTC)
Hi everyone, dose anyone know how or if you can run a eaton M90 supercharger on a carb v8 under the bonnet? seen a few cheap on ebay and thought it could be a bit of fun!
any info would be much appreciated . thanks!
Mr Void Offline
#2 Posted : Tuesday, 3 July 2007 3:04:17 AM(UTC)
Mr Void
Even if you could make up a sturdy enough mount for it I doubt it would fit under the bonnet.. Also it's suited to a 3.8L motor, fitting it to a V8, even with a smaller pulley would create a lot of heat and probably wouldn't flow enough to be worth all th
___________________
#3 Posted : Tuesday, 3 July 2007 4:40:56 AM(UTC)
You'd be better off with an M112 - as the V8 will need the greater airflow.
You will need to make an adapter plate to allow the outlet of the s/c to mate up to the manifold, and you will also need some form of fuel system, with EFI being the best all-r
This page was generated in 0.106 seconds.
