#1 Posted : Friday, 22 June 2007 7:09:32 AM(UTC)
My 2002 AU ute has all gauges stuck 95 kph & 2000 rpm. Also beeper going off under dash. Only other problem I have found is power steering was low,now topped up. All fuses OK. Any suggestions?
#2 Posted : Tuesday, 26 June 2007 2:09:24 AM(UTC)
Have you tried disconnecting your battery for an hour or so?
It ****s me to tears when the media & state politicians refer to the Federal Government
#3 Posted : Saturday, 30 June 2007 6:15:48 AM(UTC)
Yes,I did that and it fixed it for about a week and then different symtoms happened. Now no gauges, low fuel and over temp lights on. I`m guessing its the gauge cluster. Thanks for the suggestion.
