#1 Posted : Saturday, 30 June 2007 2:50:44 AM(UTC)
Mate has just bought a quite tidy VC SL/E, the 253 which is painted blue, has the prefix of 253H ----. The date code which I can't decipher, taken from just behind the timing cover, reads G 6 9. Is this motor a HT HG one or does the date code prove the block has been restamped?? Thanks in advance
#2 Posted : Saturday, 30 June 2007 3:29:43 AM(UTC)
253H is a HT-G prefix , it would have been painted blue by one of its previous owners to match the car, I did the same with a 72 HQ motor painted it holden blue and put it in my WB.
#3 Posted : Saturday, 30 June 2007 3:45:23 AM(UTC)
Views messages in topic : 15,108
Date cide actually proves it's original ie 6/7/69. You'll find the block is actually worth something rather than scrap value like most 253's.
If we all had the same (good) taste, who would buy al
JBM Offline
#4 Posted : Saturday, 30 June 2007 10:20:18 PM(UTC)
JBM
What is different about these early 253s.
I have a VH 253 Blue motor, can this blue motor have a 4" bore in it safely?
I can get a couple of red 253s from a neighbour, would one of these with dome tops and a warmish cam be a better option than a stock s
Edited by user Saturday, 30 June 2007 10:25:48 PM(UTC)  | Reason: Not specified
#5 Posted : Sunday, 1 July 2007 12:21:52 AM(UTC)
Hi Guys.
There is not enough metal wall thickness to bore a 253 out to 4". A 253's standard bore size is 3.625". That means you would be boring it a further 0.375". That's 3/8" (or nearly 10mm for the metric heads) which is a big ask for any cyinder bl
#6 Posted : Sunday, 1 July 2007 3:13:41 AM(UTC)
My point about it's value is to someone restoring a HT/G Monaro.
