#1 Posted : Tuesday, 10 July 2007 7:23:33 AM(UTC)
Hi all,
I have just picked up a new vk commo that needs a blue slip and the window demister doesn,t work. ( it works feet, face but no windscreen) is this a vacume pipe issue or the switch??
Any help is appreciated
hz dude Offline
#2 Posted : Tuesday, 10 July 2007 7:45:07 AM(UTC)
hz dude
does it make a sucktion noise when turned that way it should but does it sound like it leeks most times its hardened vac hoses just cut a bit off see how you go or the ventiltion to the screen has come a drift a tight squeeze for a hand but on the drivers
