#1 Posted : Wednesday, 11 July 2007 5:00:18 AM(UTC)
Hi,
Would anyone out there in car land know if the wiring on any of the front wheels can be changed for the ABS without replacing the notched rotors?
Does it come as a seperate loom or does Holden want you sell you the lot?
My light comes on occasionly and I think it's one of the front wheel sensor wiring probably breaking with the movement of the car?
Any help is appreciated.
F
#2 Posted : Wednesday, 11 July 2007 7:48:46 AM(UTC)
In the VS the sensor is built into the rear of the sealed front hub. There are no notched rotors like VP & VQ models had for ABS.
It is common for the wheel sensors to fail at this age now.
You can replace the loom from between the plug in the engi
