YetAnotherForum.NET Help
6pak Offline
#1 Posted : Monday, 16 July 2007 5:58:08 AM(UTC)
6pak
Hi Folks
I'm going to be fitting the windsor back into my ZD in the near future. I'm using a load leveler to make it a bit easier on the back and I'm planning to fit the C4 and engine in as one unit. My plan is to lift it with some engine lifting tags that I have made. Basically they are 4mm plate cut into a triangular shape with rounded points. I've drilled the base to match the exhaust bolt holes and have another hole at the pointed end for a shackle. I plan to attach one of these to each corner of the engine with high tensile bolts and use them to lift the negine in. I've checked out other lifting tags on late model cars and they are of a similar thickness. Is 4mm plate meaty enough for the job given the load is spread over 4 points?
383XB Coupe Offline
#2 Posted : Monday, 16 July 2007 11:26:26 PM(UTC)
383XB Coupe
1st thing when doin this, even though its on 4 points you have to assume that the load is only held on by 2 points at any one time saying that, 4mm plates are NOT safe in my opinion to do the job.
Also because you have made these yourself, they haven't
6pak Offline
#3 Posted : Tuesday, 17 July 2007 4:01:32 AM(UTC)
6pak
Hi 383XBCoupe. You are actually echoing my own concerns there. My preference is to buy something made for the job, where can I pick something like this up? (I'm in WA).
383XB Coupe Offline
#4 Posted : Tuesday, 17 July 2007 5:29:15 AM(UTC)
383XB Coupe
Not sure where you will get it, maybe try a car place eg autobarn or something like that.
On the other hand look up a place that sells or produces rigging gear. maybe they could produce/already have something that will suit what you need. Or be able t
#5 Posted : Tuesday, 17 July 2007 7:25:48 AM(UTC)
Hi 6pak, 4mm would probably be ok as long as the bolt holes and the shackle hole were not too close to the edges and the lifting chain did not pull at the brackets at a angle.
To be safe, make a set out of 1/4" inch plate and with enough metal so the
383XB Coupe Offline
#6 Posted : Tuesday, 17 July 2007 9:49:09 AM(UTC)
383XB Coupe
Sorry but right now I am gonna be very blunt. I am a rigger and have also spoken to this with another more experienced rigger and we have found many flaws.
First off. 6pak, the most biggest flaw with it all is that you have doubts with it workin, this
6pak Offline
#7 Posted : Tuesday, 17 July 2007 8:24:41 PM(UTC)
6pak
Hi 383XBCoupe. I was already talked out of using my homemade stuff with your first post and Lincon Thunderbirds subsequent question about the thickness of the plate! I'm visiting Coventrys today to see if they have lifting tags and also making a few call
#8 Posted : Wednesday, 18 July 2007 1:26:44 AM(UTC)
Hi, use the factory ones if you can get them.
They will be fine.
They work well.
BrianH Offline
#9 Posted : Wednesday, 18 July 2007 10:59:51 AM(UTC)
BrianH
6pak
4 mm does not sound very much until you look at the tensile strength of steel. Even ordinary structural mild steel from the local hardware store is about 35,000 lbs per sq inch. A Windsor weighs less than 500 lbs which is less than many six cyli
6pak Offline
#10 Posted : Thursday, 19 July 2007 3:21:58 AM(UTC)
6pak
Thanks Brian
Your point about two lifting points makes sense. I'm seeing the XR8 owner tomorrow night so i think I'll copy whatever is on her car. In the past I've welded up chain to flat plate lift engines in and out but I'm particularlt twitchy this
keithholden Offline
#11 Posted : Thursday, 19 July 2007 4:10:32 PM(UTC)
keithholden
I put a 350chev with Th400 trans into my HQ with a tow rope and a few other ropes I found around the place.. I would go ahead and do it with what you have but also put a tow rope around 2 parts of the engine and tie it and hook it on the lifting equipment
6pak Offline
#12 Posted : Saturday, 21 July 2007 6:21:28 AM(UTC)
6pak
Thanks to everyone for their input. In the end my engine guy has sourced some AU heads for the motor which come with lifting tags so it all worked out nicely in the end, adjustable top end, more power and less chance of dropping the whole lot on my foot.
#13 Posted : Tuesday, 24 July 2007 7:22:45 PM(UTC)
In case anyone else is interested here is a pair of brackets.
http://cgi.ebay.com.au/3...2351QQrdZ1QQcmdZViewItem
This page was generated in 0.138 seconds.
