ok, back to the brake calipers, ive found a set of VP clubsport calipers. Apparently they are PBR calipers, are these OEM and will they bolt straight on to the salisbury V8 diff?
If it doesn’t burn fossil fuels, it’s not a spo
Thanks: 1 times Was thanked: 244 time(s) in 218 post(s)
HI boom.
The VP Clubsport just uses standard Holden brakes, thats standard rears & V8 fronts.
Remember though, that the Clubsport (like SS & Calais) has IRS & the IRS calipers use different mounts. So no, they wont bolt up to early Commodore Salisbu |
HI boom.
The VP Clubsport just uses standard Holden brakes, that's standard rears & V8 fronts.
Remember though, that the Clubsport (like SS & Calais) has IRS & the IRS calipers use different mounts. So no, they won't bolt up to early Commodore Salis |
ok thanks for that terry
If it doesn’t burn fossil fuels, it’s not a sport.
