vintageholden Offline
#1 Posted : Tuesday, 17 July 2007 5:39:10 AM(UTC)
vintageholden
i have a blue 3.3 with efi and want to go straight gas
do i nead the injecters any more or the computer as the gas goes into the throttle body?????
thanks
#2 Posted : Tuesday, 17 July 2007 6:19:21 AM(UTC)
No.
HZute-efi-VS5L Offline
#3 Posted : Tuesday, 17 July 2007 6:11:18 PM(UTC)
HZute-efi-VS5L
om about to go straight gas on my vs v8 and im told that i can get rid of the fuel side of it as it need it to start on cold mornings? there must be a way around this?
www.stickthisdecals.com.au
#4 Posted : Tuesday, 17 July 2007 10:42:21 PM(UTC)
With the VS V8 you are cheering as you can readily keep both, and run it like Holden did with the dual fuel VP.
What you need to do is get a Memcal for a V8, and replace the Eprom with an socket and buy and Eprom (or EEprom or FlashRom) twice as big. Als
#5 Posted : Wednesday, 18 July 2007 1:07:31 AM(UTC)
vintageholden
No.???????????
any more info
PLEASE
no i dont nead them ????????
#6 Posted : Wednesday, 18 July 2007 4:28:24 AM(UTC)
No you don't need to keep the injectors and ECU as the VK EFI engine uses a HEI distributor. It just gets converted like a carbied engine. Make sure you get hardened seats in a blue/black 202 though. GasResearch can also sell you an LPG throttlebody.
_
#7 Posted : Wednesday, 18 July 2007 6:12:41 AM(UTC)
vintageholden
thankyou
can i use the same throtle body?????
if so what pipes do i block off etc
#8 Posted : Wednesday, 18 July 2007 6:29:21 AM(UTC)
You can. It just looks better with the aftermarket one. Not sure about which to block off. You'll probably only need a vacuum point for the dizzy.
If we all had the same (good) taste, who would b
#9 Posted : Wednesday, 18 July 2007 6:31:44 AM(UTC)
vintageholden
your a good man thanks
