Fastlane
Holden Forums
Holden General Discussion
VS engine light and bad fuel economy Help please.
My Vs engine light is coming on the fault is O2 sensor they have been replaced but the light reappears, i only get 360-380klms to a tank (wagon 75 ltrs ).Not driven hard.V6. Running rough even after new plugs ect. Fuel gauge and temp not accurate. Are these problems computer related or seperate issues. Car has done 250 000 approx and had the problem for a while. I believe the choke may be coming on when the o2 sensor does not register hence the bad economy. Can some one please help or point me in the right direction. North west Sydney.
Hi hm69hk
This is where many people use ECU fault codes incorrectly. Just because an O2 sensor code is coming up, it doesn't mean that the O2 sensor is faulty. There are many different O2 sensor codes, it depends on the exact wording. The more likely s |
Thanks Terry i will call you back to make a time in the next week or two,trying to sort out days off and kids to school ect.(wifes car). Thanks for the quick and knowledgable reply.
Fastlane
Holden Forums
