#1 Posted : Sunday, 22 July 2007 12:12:00 AM(UTC)
hey guys wondering if ne1 could help me out.
I want to know whether all the panels and bolts match up the same on a hq to a hz as i need a donor car for a lot of bits n pieces n bolts for my hq but cant ind ne hq's to use as a donor car yet.
JBM Offline
#2 Posted : Sunday, 22 July 2007 3:31:02 AM(UTC)
JBM
The doors are the same, the HZ boot has a higher section in the middle.
The front scuttle or cowl is different and doesn't line up with bonnet. The guards are a different shape at the front because the nose cones are different.
James
Edited by user Sunday, 22 July 2007 3:51:12 AM(UTC)  | Reason: Not specified
#3 Posted : Sunday, 22 July 2007 8:39:26 AM(UTC)
if you use the whole front end panels fenders, bonnet, nose cone, it will all bolt on BUT the two ridges on the cowl just near the wipers and running down to the nose cone do not line up, but really just for a runabout you wouldn't notice it.
I had a ut
