basketcasebear Offline
#1 Posted : Wednesday, 25 July 2007 4:12:47 AM(UTC)
basketcasebear
hey yall,
a little bit of help if possible?
just put in temperature switch connected too, an after market fan,
on fan, and relay,,, there are red, black, blue, and a smaller tan coloured wire.
i presume red= pos, black =neg, tan =ignition,, blue, buggered if i know?
on temp switch, there are 2 terminals, with nothing in diagram or on unit, to say which is positive or neg??
if i knew this i might be able make sure it works??
any help would be gratefully received,
thanks
ptpro
DOH!!!
Mr Void Offline
#2 Posted : Wednesday, 25 July 2007 4:41:36 AM(UTC)
Mr Void
I'm a little confused too?
The fan has 4 wires? The same as the relay?
Is the swicth just a manual toggle switch or when you say temp switch do you mean it's triggered by a heat source (presumedly that it gets attached to)?
Did all these compone
___________________
Mr Void Offline
#3 Posted : Wednesday, 25 July 2007 4:41:36 AM(UTC)
Mr Void
Im a little confused too?
Is the swicth just a manual toggle switch or when you say temp switch do you mean its triggered by a heat source (presumedly that it gets attached to)?
Did all these component
___________________
Mr Void Offline
#4 Posted : Wednesday, 25 July 2007 5:07:51 AM(UTC)
Mr Void
Here's a wiring diagram of how to hook it all up (just disregard the 2nd fan and lh relay for the manual switch). I'm presuming the relay is a normal unit that has the numbers on the bottom (next to each pin)... they corrospond to the numbers in the diag
___________________
Mr Void Offline
#5 Posted : Wednesday, 25 July 2007 5:07:51 AM(UTC)
Mr Void
Heres a wiring diagram of how to hook it all up (just disregard the 2nd fan and lh relay for the manual switch). Im presuming the relay is a normal unit that has the numbers on the bottom (next to each pin)... they corrospond to the numbers in the diagra
___________________
#6 Posted : Wednesday, 25 July 2007 6:24:13 AM(UTC)
basketcasebear
hey thanks mr void,
I am unable to view your diagram? dont know why?
it is the relay that has 4 wires, red black blue and tan, with the tan being smaller,,the actual fan only has 2 wires, and i bet ya $100 bucks these two wires are positive and negat
DOH!!!
JBM Offline
#7 Posted : Wednesday, 25 July 2007 7:40:48 AM(UTC)
JBM
The temp switch will be on or off so polarity doesnt matter, when its on the power runs to the fan and when its off it doesnt so the tabs can be connected either way.
The relay will switch your fan on and off without the temp switch carrying a lot of a
Edited by user Wednesday, 25 July 2007 7:44:50 AM(UTC)  | Reason: Not specified
jabba Offline
#8 Posted : Wednesday, 25 July 2007 3:37:29 PM(UTC)
jabba
The relay is a heavy duty switch. It lets you put the switching on the shortest run from the power supply to the device, and the control where you like it.
Two (bigger) wires will be the feed from the battery to the relay, and from the relay to the +v
#9 Posted : Friday, 27 July 2007 8:27:20 AM(UTC)
basketcasebear
thanks jabba and jbm, and everyone, i am sure i can now fix this conumdrum
then, i can get stuck into another conumdrum,
so many conumdrums!!
so little time!!!
ptpro
DOH!!!
#10 Posted : Wednesday, 15 August 2007 1:36:49 AM(UTC)
basketcasebear
I DID IT!!! its alive,,,it vorks,,fabbo...
thanks to everyone who helped me,,,
and my mum,,
ptpro
DOH!!!
