6pak Offline
#1 Posted : Thursday, 26 July 2007 9:06:18 AM(UTC)
6pak
Hi folks. I have converted my ZD to an accelerator cable rather than linkages. Superoo spares recommended using an XB set up which i bought from them along with a new cable. It's all installed but the cable doesn't stay in the end of the accelerator pedal linkage. All I've got is a bar with a slot in the end and a bit of a dent to accomodate the ball on the end of the cable. Is there some kind of retaining clip that should have been included with it?
#2 Posted : Thursday, 26 July 2007 5:46:23 PM(UTC)
Yes, there is a little spring steel clip that goes over the end of the cable and clips around the acc pedal rod. Should be able to get one at the wreckers..
6pak Offline
#3 Posted : Friday, 27 July 2007 2:15:46 AM(UTC)
6pak
Thanks Nathan. As they said they would sell me "everything I need to complete the conversion" I think a call to the supplier is in order. :)
This page was generated in 0.122 seconds.
