A mates got a HX tonner with half a rat trap and half a cable on the clutch setup is this normal its a six with a aussie 4 how many were made with this setup was it just tonners or just HXs just a bit confussed never seen it before any help would be enlighting thanx dudes
its beer o'clock |
On The Other Hand There's Finger's |
All HX and early HZ manuals had this setup. Later HZ went to the WB style full cable setup. You can pick in HZ which it's meant to have by the holes for the clutch pedal - early has 1, later has 2.
______________________________________________________ |
All HX and early HZ manuals had this setup. Later HZ went to the WB style full cable setup. You can pick in HZ which its meant to have by the holes for the clutch pedal - early has 1, later has 2.
_______________________________________________________ |
its good to know these things for the future thanx my HZ is the later one 202 three on the tree nice neat standard
its beer oclock |
it's beer o'clock |
