ive decided to put a 4 speed in my WB ute. the ute is running a 253 HX engine. what type would be best suited to this conversion. after something reliable at a reasonable costs. the motor is standard and i'm NOT going to be doing burnout's or anything like that.
i know i'll need pedals, cables, bellhousing etc. whats a decent garden variety Box thats easy to get hold of all the components. also would i need to chase up another cross member and tail shaft or would the ones from my auto bolt straight up, cheers craig
Thanks: 1 times Was thanked: 558 time(s) in 533 post(s)
If its a trimatic the tailshaft, crossmember, speedo cable and the hole in the floor will be the same as an aussie 4 speed. Just the driven gear on the end of the speedo cable will probably be different. The WB will already have the connectors under the d Edited by user Friday, 27 July 2007 10:19:09 PM(UTC)
| Reason: Not specified |
If it's a trimatic the tailshaft, crossmember, speedo cable and the hole in the floor will be the same as an aussie 4 speed. Just the driven gear on the end of the speedo cable will probably be different. The WB will already have the connectors under the Edited by user Friday, 27 July 2007 10:19:09 PM(UTC)
thank you for your reply byron rich it was very informative. it does have a trimatic. what's wrong with m21 and how can i tell the difference between the 3 gearboxes, are they stamped? i'm not sure of my final drive gear ratio but i do know it is ve Edited by user Friday, 27 July 2007 11:24:40 PM(UTC)
thank you for your reply byron rich it was very informative. it does have a trimatic. whats wrong with m21 and how can i tell the difference between the 3 gearboxes, are they stamped? im not sure of my final drive gear ratio but i do know it is very Edited by user Friday, 27 July 2007 11:24:40 PM(UTC)
All boxes look exactly the same externally, just V8 has the longer input shaft. The only 100% accurate way to tell is to pull off the side cover and read the part number off the cluster gear. M21 is too tall in 1st for a 253 in a heavy car, BUT if you hav |
thanks for the advice. i spoke to the bloke at the wreckers today and he said he could do me a full conversion kit for $550. he just sold an M20 but will try get another for one for me. i'll jump under the ute tommorow and see what my final drive gearing
thanks for the advice. i spoke to the bloke at the wreckers today and he said he could do me a full conversion kit for $550. he just sold an M20 but will try get another for one for me. ill jump under the ute tommorow and see what my final drive gearing i
It'll be 3.55 or 4.44. Even if you buy an M21 it can be converted to M20 or M22. Most secondhand aussie 4-speeds are buggered. Trouble is you don't know it until they break. I'd rebuild it before you put it in, and in that case it doesn't really matter w |
Itll be 3.55 or 4.44. Even if you buy an M21 it can be converted to M20 or M22. Most secondhand aussie 4-speeds are buggered. Trouble is you dont know it until they break. Id rebuild it before you put it in, and in that case it doesnt really matter what |
the ute will very rarely go out on the open road at the moment, with the gearing i have i think i'll probably get away with any box. but i do like the idea of the m22 for future ratio changes and more flexability for different driving conditions. thank Edited by user Saturday, 28 July 2007 4:09:07 PM(UTC)
the ute will very rarely go out on the open road at the moment, with the gearing i have i think ill probably get away with any box. but i do like the idea of the m22 for future ratio changes and more flexability for different driving conditions. thanks Edited by user Saturday, 28 July 2007 4:09:07 PM(UTC)
i checked my final drive. its 3.55 ill go for the m20 if i can get one, if worse comes to worse ill get the m21. further down the track when ive got enough money ill change both the diff to higher ratio and m22 box ratios for the best of both worlds, che
i checked my final drive. it's 3.55 i'll go for the m20 if i can get one, if worse comes to worse i'll get the m21. further down the track when i've got enough money i'll change both the diff to higher ratio and m22 box ratio's for the best of both world
Coley
Let me know if you cant find one as I think I know where a 2nd hand V8 M20 is.
Byron
Coley
Let me know if you can't find one as I think I know where a 2nd hand V8 M20 is.
Byron
