#1 Posted : Tuesday, 31 July 2007 11:53:36 PM(UTC)
Hi, Can anyone tell me what this diff is out off and the ratio. No 3969340NF, J219 ( 9 maybe an 8 ) , No on crown wheel, 2GM3790629 12 37 6 69. Cant see a ratio stamped on crown wheel. Cheers.
#2 Posted : Wednesday, 1 August 2007 12:36:24 AM(UTC)
Hi bazza30555.
My guess is a 3.08, you can calculate it youself. You get the number of teeth on the crown wheel (37) & divide it by the number of teeth on the pinion (12).
37/12= 3.08333
Dr Terry.
#3 Posted : Wednesday, 1 August 2007 1:26:10 AM(UTC)
Is the date stamp 21-9-69 meaning it would have came out of HT
#4 Posted : Thursday, 2 August 2007 6:30:18 AM(UTC)
Hi, I think this diff is a hk,t,g unit but I am not sure which one it suits. How can I tell if its what people refer to as a early Eaton diff.Cheers.Bazza.
#5 Posted : Thursday, 2 August 2007 4:25:36 PM(UTC)
It probably won't be an Eaton as they were only early HK. Eaton are a clutch type LSD, the later Borg Warner (I think it was Borg Warner) are a cone type LSD.
Does it have 10 bolts on the crownwheel?
_________________________________________________
#6 Posted : Thursday, 2 August 2007 4:25:36 PM(UTC)
It probably wont be an Eaton as they were only early HK. Eaton are a clutch type LSD, the later Borg Warner (I think it was Borg Warner) are a cone type LSD.
__________________________________________________
#7 Posted : Sunday, 5 August 2007 4:51:11 AM(UTC)
Hi, Byron. Yes it has 10 bolts on the crown wheel.Cheers.John.
#8 Posted : Sunday, 5 August 2007 5:25:37 AM(UTC)
It's a 10-bolt then. Just checking it wasn't a 12-bolt.
#9 Posted : Sunday, 5 August 2007 5:25:37 AM(UTC)
Its a 10-bolt then. Just checking it wasnt a 12-bolt.
