HZute-efi-VS5L Offline
#1 Posted : Wednesday, 1 August 2007 7:03:29 AM(UTC)
HZute-efi-VS5L
Just wondering if anyone can help.
I have a VS V8 injected engine in my HZ ute and i want to convert to full time LPG. The LPG bloke rekons that i can not get rid of the fuel tank as it needs the fuel to start. it wont start on lpg. (im not going liquid injection)
this doesnt sound right? as there is cars from the factory that are LPG only. and they dont have fuel tanks.
How do i get around the start up on lpg? so then i can tell my lpg installer that it can be done.
There is only one lpg instaler around here so i cant take it somewhere else.
I am going to remove the fuel tank so i dont want to have to start it on petrol.
Any help or sugestions would be great.
jason
www.stickthisdecals.com.au
vintageholden Offline
#2 Posted : Wednesday, 1 August 2007 9:46:12 AM(UTC)
vintageholden
DOESNT SOUND RIGHT TO ME
i have gone straight gas and done away with the injectors and removed the tank
and gone gas throttle body
#3 Posted : Wednesday, 1 August 2007 4:19:16 PM(UTC)
I've got a VN-VS 5litre in my HZ and it starts first go every time. Mine will be slightly different as it has a Redline maifold and HEI dizzy but none of that should matter EXCEPT that the distance from the mixer to the ports is longer with the factory in
#4 Posted : Wednesday, 1 August 2007 4:19:16 PM(UTC)
Ive got a VN-VS 5litre in my HZ and it starts first go every time. Mine will be slightly different as it has a Redline maifold and HEI dizzy but none of that should matter EXCEPT that the distance from the mixer to the ports is longer with the factory inl
#5 Posted : Wednesday, 1 August 2007 6:09:23 PM(UTC)
HZute-efi-VS5L
cheers for the input.
yeh byron i think thats right. he metoned that to me also. he rekoned that it needs the petrol to get the first kick. specialy on cold mornings. damn my ute is only a weekender if its going to take 5 turns of the crank instead
#6 Posted : Wednesday, 1 August 2007 6:13:08 PM(UTC)
HZute-efi-VS5L
also by lpg throttle body what do you mean there? whats the diference? im also looking at ditching the injectors. no point them being there if they arnt used.
#7 Posted : Wednesday, 1 August 2007 6:16:01 PM(UTC)
It must depend on the set up, my VR V6 does not start on petrol when gas is switched on ,my mate has a VS ute his car still started on gas even after the fuel pump packed up.
My VS stato and dads VT both start on petrol before running on gas both of thes
#8 Posted : Wednesday, 1 August 2007 10:13:55 PM(UTC)
GasResearch sell a gas throttle body that replaces the original throttle body. You have to fit an external IAC valve.
If you dont mind playing a bit go to www.moates.net and do some reading. For not many $ you can buy an ECU emulator and start playing
#9 Posted : Wednesday, 1 August 2007 10:13:55 PM(UTC)
If you don't mind playing a bit go to www.moates.net and do some reading. For not many $ you can buy an ECU emulator and start playing
BrianH Offline
#10 Posted : Thursday, 2 August 2007 5:43:01 AM(UTC)
BrianH
Jason
I have had gas powered cars for the last 19 years and all of them have started easily on gas. I lived in the Snowy Mountains for a few years with one of them and it still started even when covered with snow.
The factory system in the VP that
peter_flane Offline
#11 Posted : Thursday, 2 August 2007 7:49:34 AM(UTC)
peter_flane
I have to crank for about 10 seconds to start my straight gas engine. That is after sitting for weeks or even months, and not pressing the primer button. I do it just to give the oil some chance to get started.
#12 Posted : Thursday, 2 August 2007 10:37:45 AM(UTC)
my dual fuel injected motor would start on gas but it was harder to start when cold, which indicates extra stress on the cranking sytem. but the injectors were turned off when switched to gas so dont see a problem there.
#13 Posted : Thursday, 2 August 2007 10:37:45 AM(UTC)
my dual fuel injected motor would start on gas but it was harder to start when cold, which indicates extra stress on the cranking sytem. but the injectors were turned off when switched to gas so don't see a problem there.
wantree Offline
#14 Posted : Friday, 3 August 2007 9:41:44 AM(UTC)
wantree
The problem is that it is hard for an engine to develope enough vaccuum initially to open the gas carby or second stage regulator without the kick from the fuel. Most systems just keep the power on to the injectors for the first few seconds of ignition. Y
#15 Posted : Friday, 3 August 2007 9:28:15 PM(UTC)
Yep you are being told porkies. My Falcon is setup to start on petrol and gas but I am having fuel pump over revving issues with it so I have un plugged the fuel pump. The only time the car is even remotely hard to start is on a cold Canberra morning when
rambo Offline
#16 Posted : Monday, 6 August 2007 8:04:03 AM(UTC)
rambo
You don't need petrol to start gas cars. If you have an impco converter model L then you need to look on the side towards the front face plate. you will notice a black cap. 7/16th. Remove this cap and place a 1/8th brass fitting straight fitting tail barb
rambo Offline
#17 Posted : Monday, 6 August 2007 8:04:03 AM(UTC)
rambo
You dont need petrol to start gas cars. If you have an impco converter model L then you need to look on the side towards the front face plate. you will notice a black cap. 7/16th. Remove this cap and place a 1/8th brass fitting straight fitting tail barbe
#18 Posted : Monday, 6 August 2007 8:37:26 AM(UTC)
HZute-efi-VS5L
thankyou rambo i replied to you in the other message! you have been extreamly helpful!
#19 Posted : Wednesday, 8 August 2007 11:25:59 PM(UTC)
Gday mate,
Ive got a 253 in my HG prem, on dual fuel. Ive found that turning the ignition to ON a couple of times before start injects enough gas for ignition. Im no expert here - but I believe there is a solenoid which allows an inital hit of gas for
#20 Posted : Thursday, 9 August 2007 2:15:55 AM(UTC)
Boyle’s law states that, at a constant temperature, the volume of a given gas is inversely proportional to the pressure of which it is subjected to.
Guest (10)
This page was generated in 0.128 seconds.
