HZute-efi-VS5L Offline
#1 Posted : Thursday, 2 August 2007 5:22:50 AM(UTC)
HZute-efi-VS5L
As some may have read, Im looking to go straight LPG.
eng specs:
VS 5 L injected.
extractos 2.1/2 dual system.
costom made chip to suit LPG and my specs.(just got to put lpg on now)
have been looking at the gas research throttle bodies. and just wondering on sugestions of what size i should go for? eg. S350, S400, S440, S480, S510.
Will my standard manifold from the vs eng be ok?
Im not after huge power at this stage as i am in the process of locating another block so i can stroke it, port heads, cam, new manifold etc etc etc.
So im after sugestions for this stage. It will be about 12months before i have a block built ready so i want to convert to straight lpg now for the meantime.
Also am i better off getting a throttle body thats too big for my engine? so it will be big enough for the 355 stroker? or am i better off just getting a new one later on...
Cheers!
jason
www.stickthisdecals.com.au
rambo Offline
#2 Posted : Monday, 6 August 2007 7:50:43 AM(UTC)
rambo
I don't know if you have received any feedback on your problem yet, as I am in the lpg fitting game. I can say that your current engine will support gas as it stands. If you however at a later stage wish to stroke the engine and port the intake at all the
rambo Offline
#3 Posted : Monday, 6 August 2007 7:50:43 AM(UTC)
rambo
I dont know if you have received any feedback on your problem yet, as I am in the lpg fitting game. I can say that your current engine will support gas as it stands. If you however at a later stage wish to stroke the engine and port the intake at all then
#4 Posted : Monday, 6 August 2007 8:36:59 AM(UTC)
HZute-efi-VS5L
rambo thankyou very much for your help. i have had lots of info good and bad. some dickhead responce too! expecialy on aussie V8 forum..... yours has been the most helpful yet.
I have decided to go with the gas research tb. as i can fit it and sti
rambo Offline
#5 Posted : Monday, 6 August 2007 9:52:23 AM(UTC)
rambo
I'm glad my info is helpful to your quest. I do know about the gas research system you want to fit. the 510 is definately big enough for your stroker requirements. To tune that system you need a gas analyzer and preferably a dyno. The dyno is not essentia
rambo Offline
#6 Posted : Monday, 6 August 2007 9:52:23 AM(UTC)
rambo
Im glad my info is helpful to your quest. I do know about the gas research system you want to fit. the 510 is definately big enough for your stroker requirements. To tune that system you need a gas analyzer and preferably a dyno. The dyno is not essential
#7 Posted : Monday, 6 August 2007 6:05:16 PM(UTC)
HZute-efi-VS5L
rambo once again thankyou for your help! My gas fitter has never used gas research and we are out in the sticks so there is no where else i can go.
i will grab it i think and see how we get on. im sure the gas research mob will help us out also. but
#8 Posted : Tuesday, 14 August 2007 7:02:30 AM(UTC)
Hi HZute, I had a GRA 510 on my 5.0l in a VS ute, it pulled up around 5000rpm. Engine now stroked to 383 with custom twin GRA (510&440) manifold. If you would like to contact me E-mail- [email protected] I can forward you all specs, power, build p
#9 Posted : Tuesday, 14 August 2007 8:38:15 AM(UTC)
cheers mate
email sent...
