#1 Posted : Sunday, 5 August 2007 3:47:58 AM(UTC)
i have a 202 red and a 4 speed in my HR it is a new motor 1500 - 2000 ks on it .it has a rattleing noise from the back of the motor cluch aria i just changed the spigot and through out berings but it is still making the noise it is worse under light power so i dont think it is a bigend and i have chekt the lifters what coud it be?
#2 Posted : Sunday, 5 August 2007 3:53:20 AM(UTC)
Flywheel bolts?
#3 Posted : Sunday, 5 August 2007 4:02:07 AM(UTC)
thanks ill have a look at that
adam PERTH Offline
#4 Posted : Sunday, 5 August 2007 7:24:24 AM(UTC)
adam PERTH
what sort of 4 sp is it?
the reason is that from memory GM (aussie 4 sp) spigots are 13 mm, and toyota (i.e. celica 4 sp are 15 mm.)
hence, a GM box imput shaft into a toyota Spigot is noisy as it floats under minimal load.
more than likely flywhee
#5 Posted : Sunday, 5 August 2007 10:57:45 AM(UTC)
big ends are worse under light power/throttle. mains are worse under load. check the flywheel cover under the gearbox a loose one on my car gave a similar noise,the flywheel was hitting it under certain conditions.
