#1 Posted : Monday, 6 August 2007 8:39:46 PM(UTC)
Hi,
my Falcon ute 96 was running fine parked it one night then next morning it won't start...
fuel comes through fine, no spark on plugs.
But a cartridge fuse had blown under the dash, replaced it and it didn't blow again but still no spark.
Any hints or other procedures I can try...
#2 Posted : Monday, 6 August 2007 10:31:46 PM(UTC)
We tested the relay's and they click over fine...
#3 Posted : Wednesday, 8 August 2007 12:15:46 AM(UTC)
Ignition module or coil, if in doubt the coil is cheap but awkward to get to? that is my general experience with these.
#4 Posted : Wednesday, 8 August 2007 12:18:19 AM(UTC)
Hello Russel,
Does your ute have smartlock? if so you may need to reset it. disconnect the battery for an hour then reconnect if it still won't start I remember something about leaving the ignition on for about 90 minutes.
You say it's a 96 mod
