Handgunner Offline
#1 Posted : Monday, 13 August 2007 7:12:12 AM(UTC)
Handgunner
Hi everyone...
I am wondering if someone can have a stab at what power the engine combination i am about to describe should make?
Ok ...
Its a Commodore Blue 202 not sure if its bored out( i assume it is 40 over at least ) it has Roller rockers . 12 port head and triple SU carbs,lumpy cam and extractors. ..i was told it was in a LX Torana which went real fast...
And thats all i know.. i realise that i really need to provide more details...eg, shaved head ..porting, cam profile,etc.But i dont know !
So just a basic estimate will be cool...
Also, my 186 is in trouble , so as the 202 isnt gonna stay in my panno (307 going in ) i might whack it im my HT Prem daily driver...
So here are more questions, it will be run on gas, so the tripples will go...what carby would suit this donk on gas..?? 350 Holley.Webber .WW2 Strommy?( its a Trimatic ) hi way ratio diff... or , if its a little revver, will it be no good for a hi way car ?
I want economy ..ie torque.
Thanks for the answers :)
Bang Bang
Bang Bang
vintageholden Offline
#2 Posted : Monday, 13 August 2007 8:34:39 AM(UTC)
vintageholden
i would get blue 3.3 efi inlet manifold with gas throttle body
something like gas reasurch seen a few on ebay
block off the injecter holes etc
they run well
will have to retime the car as well
dizzy etc..........
http://cgi.ebay.com.au/gas-research-
Edited by user Monday, 13 August 2007 8:36:00 AM(UTC)  | Reason: Not specified
#3 Posted : Monday, 13 August 2007 10:01:18 PM(UTC)
Problem is LPG doesn't like real lumpy cams. And a lumpy cam also won't give you torque, well not where you want it anyway.
As for power, well that depends upon how well it was all matched up. If it's all done ad-hoc by someone that doesn't know what the
#4 Posted : Monday, 13 August 2007 10:01:18 PM(UTC)
Problem is LPG doesnt like real lumpy cams. And a lumpy cam also wont give you torque, well not where you want it anyway.
As for power, well that depends upon how well it was all matched up. If its all done ad-hoc by someone that doesnt know what they ar
Handgunner Offline
#5 Posted : Monday, 13 August 2007 10:32:05 PM(UTC)
Handgunner
Ok, cool.... i will look into the induction and also try and work out exactly what cam is in her.... lumps a bit at idle , but hopefully its not to savage :) i didnt think its was really an engine suited to a heavy car with an auto..... but it might be
Bang Bang
#6 Posted : Tuesday, 14 August 2007 12:17:31 AM(UTC)
vintageholden
get a gas cam
and black 3.3 head
peter_flane Offline
#7 Posted : Tuesday, 14 August 2007 5:26:16 AM(UTC)
peter_flane
Gas cam definitley makes a smoother torquier difference, especially if you plan on running primarily or only on LPG. They have a longer exhaust duration. My old 9 port 202 had 97KW at the back wheels on LPG with a gas cam and 350 Holley and 'Stage 3' Head
peter_flane Offline
#8 Posted : Tuesday, 14 August 2007 5:26:16 AM(UTC)
peter_flane
Gas cam definitley makes a smoother torquier difference, especially if you plan on running primarily or only on LPG. They have a longer exhaust duration. My old 9 port 202 had 97KW at the back wheels on LPG with a gas cam and 350 Holley and Stage 3 Head.
This page was generated in 0.102 seconds.
