mrhj253 Offline
#1 Posted : Monday, 13 August 2007 7:41:33 AM(UTC)
mrhj253
hi guys i have a 308 on gas and i have a hz gts dash i am wondering where the oil gauge should sit when you are driving or idling for the problem i have is when i turn ignition on the oil pressure gauge goes all the way up then when i start the car it just goes all the way down and does not give a reading do you have any advice on what would be wrong and what to fix cheers
jump on if you want a holdon
jabba Offline
#2 Posted : Monday, 13 August 2007 3:14:21 PM(UTC)
jabba
It sounds like you have an oil pressure light switch rather than an electric oil pressure sender.
Check out wreckers or rare spares for an HZ oil pressure sender.
j
Keep the shiny side up, and the gre
