ozjason Offline
#1 Posted : Thursday, 16 August 2007 6:41:02 AM(UTC)
ozjason
Hi,
The old utes running well, but between 70km/h and 90km/h on the highway, sometimes the steering wheel and column will vibrate up and down really quickly. I can see it moving. Doesn't happen every time, but just occasionally while on the highway. It's not side to side, it's up and down.
It's not uncomfortable to drive, doesn't pull to any side, and if I clutch and let the engine idle, it continues. I can accelerate through it, and it slips along quite nicely. Slow down and it goes away as well.
It's a stock non-power steering setup, column shift manual HQ ute. Front wheel bearings are freshly done, and are not too tight or too loose. Steering shaft doesn't seem to have any play, and I can't find any steering or suspension components that have any play, either.
Is this something common that any of you have experienced? Any ideas? It's a bit of a worry... Appreciate any suggestions.
Jason.
hz dude Offline
#2 Posted : Thursday, 16 August 2007 7:11:20 AM(UTC)
hz dude
wheel balance. wheel allingment and worn upper or lower
ball joints all contibute too these things off the top
of my head start with the cheapest things then work
your way up the list good luck
its beer oclock
Edited by user Thursday, 16 August 2007 7:12:31 AM(UTC)  | Reason: Not specified
hz dude Offline
#3 Posted : Thursday, 16 August 2007 7:11:20 AM(UTC)
hz dude
it's beer o'clock
arse_wipe Offline
#4 Posted : Thursday, 16 August 2007 6:13:04 PM(UTC)
arse_wipe
If its the column that is shaking and not the steering wheel, then being a column shift, I would suggest that you are getting a driveline vibration being transferred through the linkages to the column, check you unis and the gearbox rear bearing for play,
John
Silence is non-committal
arse_wipe Offline
#5 Posted : Thursday, 16 August 2007 6:13:04 PM(UTC)
arse_wipe
If it's the column that is shaking and not the steering wheel, then being a column shift, I would suggest that you are getting a driveline vibration being transferred through the linkages to the column, check you uni's and the gearbox rear bearing for pla
John
arse_wipe Offline
#6 Posted : Thursday, 16 August 2007 6:13:49 PM(UTC)
arse_wipe
forgot to add, also check the gearbox mount,,,,
Chers
John
John
ozjason Offline
#7 Posted : Saturday, 18 August 2007 8:43:24 PM(UTC)
ozjason
Thanks to both of you guys. Gives me a list of things to start with. :-) Ill also check what happens when I take it out of gear at that speed - if it stops, Id say itd be an indication that its coming up through the linkages from the drive train.
Ch
ozjason Offline
#8 Posted : Saturday, 18 August 2007 8:43:24 PM(UTC)
ozjason
Thanks to both of you guys. Gives me a list of things to start with. :-) I'll also check what happens when I take it out of gear at that speed - if it stops, I'd say it'd be an indication that it's coming up through the linkages from the drive train.
