#1 Posted : Friday, 17 August 2007 2:23:10 AM(UTC)
Hi guys, I am putting a injected 304 into a HT, and need to put the alternator on the drivers side. What models had the alternator on this side, so I can just go and get the brackets from wrecker.
Thanks!!
#2 Posted : Friday, 17 August 2007 2:34:09 AM(UTC)
try rare spares, i think either vk commodore or LH LX torana brackets is what u need...
#3 Posted : Friday, 17 August 2007 3:51:43 AM(UTC)
Thanks for that, I will check it out. Anyone else with an exact model that I can hone in on??
Also, what side of the motor does the fuel enter the fuel rail?? It is a VS motor. I am guessing the drivers side and exits on the passenger side. But jus
#4 Posted : Friday, 17 August 2007 4:28:17 AM(UTC)
From memory none. They are all over on the LH side.
JBM Offline
#5 Posted : Friday, 17 August 2007 4:44:19 AM(UTC)
JBM
LH Torana is low on the drivers side real close to the fuel pump.
VH is on the same side but is a bit higher and wider, with more clearance. Depends on where your chassis rail is and any other accessories you are running.
James
Edited by user Friday, 17 August 2007 4:49:54 AM(UTC)  | Reason: Not specified
basketcasebear Offline
#6 Posted : Friday, 17 August 2007 6:40:39 AM(UTC)
basketcasebear
eddy, i had to make my own brackets for my 308 out of vb, but used the different bits and pieces of the aircon brackets, and had to slightly bend the adjust bracket, but there are plenty of holes for the bolts, mostly it was a matter of lond rod,s as wash
DOH!!!
#7 Posted : Friday, 17 August 2007 9:50:36 AM(UTC)
VB-VL commodore V8s have the alternator on the drivers side, down low, and the power steer on the passenger side.
A lot of people aim to achieve nothing in life - and h
#8 Posted : Friday, 17 August 2007 9:50:36 AM(UTC)
VB-VL commodore V8s have the alternator on the driver's side, down low, and the power steer on the passenger side.
#9 Posted : Friday, 17 August 2007 10:04:58 AM(UTC)
basketcasebear
yes thats true mick ,,but in mine , in a 98 transit conversion, i had to put the alternator at the top? wipe the aircon, so i figured, if i could change it up to the top, then it should be possible to do it with the other 304??
i am still to insta
DOH!!!
Guest (6)
This page was generated in 0.105 seconds.
