Tom Slick Offline
#1 Posted : Monday, 20 August 2007 7:47:43 PM(UTC)
Tom Slick
Gday guys,
Does anyone know where I can score some GTS 1/4 panels for my HG ute.
I'm referring to the sexy ones with the 3 slots in the side.
I know they are probably rare as rocking horse sh*t these days but dreams are free!
I'm not having much joy on ebay.
Any help?
Tom.
Don't eat the yellow snow
#2 Posted : Monday, 20 August 2007 8:48:04 PM(UTC)
they are known as front guards, not 1/4 panels, might help your search. In the US they are front fenders and in Britain, wings. 1/4 panel is generally used for the rear guards. Technically they are front quarters but nobody uses that term.
#3 Posted : Monday, 20 August 2007 10:05:21 PM(UTC)
Tom
See if you can find some good standard guards and get Rare Spares flutes welded in. It'll be cheaper in the end.
#4 Posted : Monday, 20 August 2007 10:05:21 PM(UTC)
Tom
See if you can find some good standard guards and get Rare Spares flutes welded in. Itll be cheaper in the end.
Tom Slick Offline
#5 Posted : Monday, 20 August 2007 11:30:21 PM(UTC)
Tom Slick
Cheers guys,
I did find some flutes, they are a bit rough but I reckon they would clean up all right. How clean can they get the welds for a job like that? And would it be ok to weld them into my current front guards? I've already got those ones so why b
Tom Slick Offline
#6 Posted : Monday, 20 August 2007 11:30:21 PM(UTC)
Tom Slick
Cheers guys,
I did find some flutes, they are a bit rough but I reckon they would clean up all right. How clean can they get the welds for a job like that? And would it be ok to weld them into my current front guards? Ive already got those ones so why bu
Duzty Offline
#7 Posted : Tuesday, 21 August 2007 12:25:42 AM(UTC)
Duzty
yes you can weld them in, but if you want good ones, maybe compare the ones you have to rare spares....no point in putting **** ones in...do it properly the first time.
Back to top
hg350gts Offline
#8 Posted : Tuesday, 21 August 2007 2:34:03 AM(UTC)
hg350gts
My panel beater wont weld in the rare spares ones, he says they are inferior- thinner than the holden stuff and harder to get right? Is this true?
So hes chopping up a far gone GTS guard to weld into a Kingswood one in good condition...
Duzty Offline
#9 Posted : Wednesday, 22 August 2007 1:21:14 AM(UTC)
Duzty
im pretty sure the gauge of the metal that Rare Spares press them out in is thicker than holdens panel metal...im not 100% sure, but as for them fitting, i have seen many finished examples and they look good!
[IMG]http://www.members.iinet.net.au/~rhode
peter_flane Offline
#10 Posted : Wednesday, 22 August 2007 6:05:27 AM(UTC)
peter_flane
Ultimately If I was doing a concourse or original resto I would look at putting the rear lower whole section of an original GTS guard into a Kingswood guard. If it is not an issue on those terms, and just for looks, then I would have no problems fitting t
peter_flane Offline
#11 Posted : Wednesday, 22 August 2007 6:05:27 AM(UTC)
peter_flane
Ultimately If I was doing a concourse or 'original' resto I would look at putting the rear lower whole section of an original GTS guard into a Kingswood guard. If it is not an issue on those terms, and just for looks, then I would have no problems fitting
#12 Posted : Wednesday, 22 August 2007 5:56:39 PM(UTC)
all rares panels are .9mm, all Pre HJ holden steel is 1.2mm thick, but rares panels are designed to harden once heated by the welding process, more carbon used when the steels made. same process used in new car panels used today, makes them lighter & sup
#13 Posted : Wednesday, 22 August 2007 5:56:39 PM(UTC)
all rares panels are .9mm, all Pre HJ holden steel is 1.2mm thick, but rares panels are designed to 'harden' once heated by the welding process, more carbon used when the steels made. same process used in new car panels used today, makes them lighter & s
Tom Slick Offline
#14 Posted : Wednesday, 22 August 2007 7:17:57 PM(UTC)
Tom Slick
Thanks for your pearls of wisdom fella's
Once again I have some direction!
Tom Slick Offline
#15 Posted : Wednesday, 22 August 2007 7:17:57 PM(UTC)
Tom Slick
Thanks for your pearls of wisdom fellas
Dont eat the yellow snow
This page was generated in 0.088 seconds.
