Slamd Hk Offline
#1 Posted : Thursday, 23 August 2007 8:17:27 PM(UTC)
Slamd Hk
Hi All, I went to switch on my Aircon in the vt & the compressor doesnt kick in, i have noticed a little while ago that the air wasn't too cold.
Has anyone had this problem before?
Slamd Hk
MLD
#2 Posted : Friday, 24 August 2007 6:09:46 AM(UTC)
Yeah mate, just been through this prob.
Quote:
Just to clear this up, are you saying that the blower fan (in the dash) is not working. If this is the case, the problem is purely electrical. The low pressure switch (actually a sensor on VTs) will only
Slamd Hk Offline
#3 Posted : Friday, 24 August 2007 5:18:05 PM(UTC)
Slamd Hk
Cheers Dr Terry,good to hear its a simple fix.
thanks
Slamd Hk
MLD
Slamd Hk Offline
#4 Posted : Friday, 24 August 2007 5:18:05 PM(UTC)
Slamd Hk
Cheers Dr Terry,good to hear it's a simple fix.
thanks
Slamd Hk
MLD
FastEHHolden Offline
#5 Posted : Tuesday, 28 August 2007 5:40:15 AM(UTC)
FastEHHolden
A/C wont work if your ABS sensor goes down too..usually indicated by lots of warning lights on your dash.
