edelbrock1 Offline
#1 Posted : Monday, 27 August 2007 5:13:45 AM(UTC)
edelbrock1
Just got the HT on the road after a long stint in the shed. Before it was pulled off the road it had new rotors and pads on the front. Now the brakes squeal at every available opportunity. I know this is a problem with this model. But how do you over come it?? there must be an easy way to fix it.
hz dude Offline
#2 Posted : Monday, 27 August 2007 7:16:04 AM(UTC)
hz dude
antie squeal spray . just spray it on give it a run
give another spray should be all good
bursons, repco, supercheap or autobarn your choice
its beer oclock
Edited by user Monday, 27 August 2007 7:16:57 AM(UTC)  | Reason: Not specified
hz dude Offline
#3 Posted : Monday, 27 August 2007 7:16:04 AM(UTC)
hz dude
it's beer o'clock
peterwmh Offline
#4 Posted : Monday, 27 August 2007 7:51:46 PM(UTC)
peterwmh
I had a HR Premier that did the same thing, apparently it's the brake dust being caught between the pad and rotor. The fix was to cut a slot in the pad from top to bottom but leave around 3mm to contact against the metal base of the pad. This gives a re
peterwmh Offline
#5 Posted : Monday, 27 August 2007 7:51:46 PM(UTC)
peterwmh
I had a HR Premier that did the same thing, apparently its the brake dust being caught between the pad and rotor. The fix was to cut a slot in the pad from top to bottom but leave around 3mm to contact against the metal base of the pad. This gives a res
81837 Offline
#6 Posted : Tuesday, 28 August 2007 12:05:03 AM(UTC)
81837
I have the same trouble with my Brougham, It was fine until I replaced the rotors and pads. I understand the old pads had asbestos in them so can no longer be sold. The new Kevlar pads squeal in our old calipers. I've tried the anti squeal spray and it wo
81837 Offline
#7 Posted : Tuesday, 28 August 2007 12:05:03 AM(UTC)
81837
I have the same trouble with my Brougham, It was fine until I replaced the rotors and pads. I understand the old pads had asbestos in them so can no longer be sold. The new Kevlar pads squeal in our old calipers. Ive tried the anti squeal spray and it wor
192_HG Offline
#8 Posted : Tuesday, 28 August 2007 4:22:26 AM(UTC)
192_HG
you need to run your pads in properly.
drive at 60kph, and with your foot on the accelerator, slow the car to 50kph - and repeat about 15-20 times.
then do a couple of really hot, hard stops and if your pads squeal after that, then shoot me.
if i
if i wanted a V8 in it, i would have bought one in the first place
FastEHHolden Offline
#9 Posted : Tuesday, 28 August 2007 5:34:59 AM(UTC)
FastEHHolden
Its usually vibrations between the metal backing plate of the pad and the piston...I put silastic on mine and it stopped...neutral cure silastic.
#10 Posted : Friday, 31 August 2007 4:14:40 AM(UTC)
hz dude knows what hes talking about....hey rob, thanks 4 the help with the radiator
#11 Posted : Friday, 31 August 2007 4:14:40 AM(UTC)
hz dude knows what he's talking about....hey rob, thanks 4 the help with the radiator
Guest (10)
