#1 Posted : Tuesday, 28 August 2007 3:48:28 AM(UTC)
Hey Guys
just wondering what was involved in removing a dash from a hq is it hard or quite simple. Also i heard from someone that you can get vinyl paint to paint interior door trims, has any one else heard of neone doing this and do they come out good or just look crap.
#2 Posted : Tuesday, 28 August 2007 9:07:52 AM(UTC)
you just need tiny fingers to reach in behind the dash with a 3/8 i think socket could be 5/16" to unscrew the nuts on the back of the dash pad.
(later model dash pads just unclip)and you have to take the instrument panel out.
keithholden Offline
#3 Posted : Wednesday, 29 August 2007 3:16:29 AM(UTC)
keithholden
There use to be vinyl dye which was better than the spray as it soaked into the vinyl instead of sitting on top. Not sure if you can get it any longer.
You can vinyl spray them just make sure you clean them realy well other wise it will chip off with ju
Taz2 Offline
#4 Posted : Friday, 31 August 2007 6:28:45 AM(UTC)
Taz2
Best idea is to check the manual before removing the dash pad. Some of those nuts are not the easiest to find, and if you miss one you risk breaking the backing that holds the screw thread to the back of the dashpad.
If you dont have a manual, try your l
In thrust we trust
Taz2 Offline
#5 Posted : Friday, 31 August 2007 6:28:45 AM(UTC)
Taz2
If you don't have a manual, try your
In thrust we trust
