#1 Posted : Tuesday, 28 August 2007 9:12:28 AM(UTC)
whats the best flowwing head
i was told blk are better thn yella terra?????
#2 Posted : Tuesday, 28 August 2007 4:24:32 PM(UTC)
VK EFI 3.3L black heads are the best.
The 3.3L black carby head is also good, but you need to blank off the drilled & tapped air-injection ports in the exhaust ports.
peter_flane Offline
#3 Posted : Wednesday, 29 August 2007 5:14:14 AM(UTC)
peter_flane
New cast Yella Terra heads are 12 port and flow better than standard 12 port.
