HI CAN ANYONE TELL ME IF I CAN BUY BLANK DISCS AND HAVE DRILLED TO COMMADORE FOR BETTER WHEEL SELECTION.I WISH TO KEEP STOCK CALLIPERS AS I HAVE HAD THEM RECONDITIONED CHERRS
convert to HQ, disks and rotors?. Cheaper to do it ths way?
A1 Bogan. |
Hi kanks.
With HK/T/G front discs, the disc rotor & the hub are 2 separate parts. The wheel studs are in the hub not the disc. The wheel stud pattern in the hub is difficult to alter & the hub is not replaced when fitting a new disc rotor anyway.
An |
