hg350gts Offline
#1 Posted : Friday, 31 August 2007 12:44:33 AM(UTC)
hg350gts
Hey guys
Anyone done a restoration, should there be any thing else that should be done in chrome? so far i have gathered up:
Rearview mirror thing
Sunshade support
Door kick plates
Door strikers & screws
Bolts and nuts
Glove box rails
headlight surround cups
blinker surrounds
Hate to be going back to do something obvious that I havent thought of.
ozjason Offline
#2 Posted : Friday, 31 August 2007 12:54:43 AM(UTC)
ozjason
Bonnet catch and hinges?
#3 Posted : Friday, 31 August 2007 1:02:28 AM(UTC)
whereabouts are you going to have it done?
Munromad2004 Offline
#4 Posted : Friday, 31 August 2007 1:53:08 AM(UTC)
Munromad2004
Mate the list is almost endless.
Wiper motor cover, brake booster, engine pulleys, boot and bonnet catches and strikers, bonnet hinges, alternator brackets, alternator casing, etc etc
If it's metal and you can unbolt it then there is a good chance y
#5 Posted : Friday, 31 August 2007 1:53:08 AM(UTC)
Munromad2004
If its metal and you can unbolt it then there is a good chance yo
JBM Offline
#6 Posted : Friday, 31 August 2007 1:55:18 AM(UTC)
JBM
Chroming the bonnet springs will cause them to lose their tension and the bonnet will only hold itself halfway up.
James
hg350gts Offline
#7 Posted : Friday, 31 August 2007 2:25:50 AM(UTC)
hg350gts
Hey guys.
Nah just going conservatively, sorry the question was aimed more for the stock look... but your right about being able to get everything metal done.. which has crossed my mind..
Johnno- dont know exactly yet, looking at a few places around Per
#8 Posted : Friday, 31 August 2007 2:50:44 AM(UTC)
hi mick i have only had Ultrachrome do some steel which was superb but costs an arm and a leg. i havent seen their potmetal work but would have to assume it would be pretty good. I have been told Vinci are good for bathroom fittings but keep them away fro
hg350gts Offline
#9 Posted : Friday, 31 August 2007 3:21:53 AM(UTC)
hg350gts
Hi Johnno
Thanks for the suggestions, so it looks like ill have to drop into Ultrachrome and check them out.. Let me know how the Premier turns out :)
Guest (5)
