Handgunner Offline
#1 Posted : Wednesday, 5 September 2007 7:49:25 AM(UTC)
Handgunner
Hi , i need some more advice please, i want to install a Turbo box in my HG Panno, my question is, do the aftermarket crossmembers suit both the 350 and 400 trannies? I have a 400 and will probably go with that( with tunnel mods ), but if a good 350 comes along i might use that instead ( no tunnel mods :).... i am just being cautious before i buy one...
And finally, can someone recommend a good place to get one in Victoria..
Rod Hadfield? Who makes the best ones..?
Or should i modify a Statesman etc cross member?
Thanks in advance people.... :)
Anthony
Bang Bang
Bang Bang
#2 Posted : Wednesday, 5 September 2007 4:17:36 PM(UTC)
For a TH350 just use a V8 powerglide or Saginaw crossmember with the factory (or copied) spacers. You'll have to modify a trimatic or 3 speed synchro one for a TH400 as well as the tunnel and body member.
_______________________________________________
#3 Posted : Wednesday, 5 September 2007 4:17:36 PM(UTC)
For a TH350 just use a V8 powerglide or Saginaw crossmember with the factory (or copied) spacers. Youll have to modify a trimatic or 3 speed synchro one for a TH400 as well as the tunnel and body member.
________________________________________________
