Hi , i need some more advice please, i want to install a Turbo box in my HG Panno, my question is, do the aftermarket crossmembers suit both the 350 and 400 trannies? I have a 400 and will probably go with that( with tunnel mods ), but if a good 350 comes along i might use that instead ( no tunnel mods :).... i am just being cautious before i buy one... And finally, can someone recommend a good place to get one in Victoria.. Rod Hadfield? Who makes the best ones..? Or should i modify a Statesman etc cross member? Thanks in advance people.... :) Anthony
Bang Bang |
Bang Bang |
For a TH350 just use a V8 powerglide or Saginaw crossmember with the factory (or copied) spacers. You'll have to modify a trimatic or 3 speed synchro one for a TH400 as well as the tunnel and body member.
_______________________________________________ |
For a TH350 just use a V8 powerglide or Saginaw crossmember with the factory (or copied) spacers. Youll have to modify a trimatic or 3 speed synchro one for a TH400 as well as the tunnel and body member.
________________________________________________ |
