hazzard county Offline
#1 Posted : Tuesday, 11 September 2007 6:43:18 AM(UTC)
hazzard county
gday fellas just going through restoring process on my 10 bolt & just checking all the components are genuine it has ventalated drums, a rear orange sway bar which bolts from memory to the leafspring cradle & to the chassis & radius rods which i know are original & also on the leaf springs which it has 3 of . also has a 4th leaf which looks to be some sort of helper spring are all of the above genuine for a manual monaro advice needed thanks
Edited by user Tuesday, 11 September 2007 11:38:58 AM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 11 September 2007 4:15:52 PM(UTC)
Hazzard
Was it you who wanted the photo of the clutch slave brackets? I was cleaning up my desk and found them and then remembered I had to take a photo.
If we all had the same (good) taste, w
#3 Posted : Tuesday, 11 September 2007 5:41:03 PM(UTC)
Hi hazzard.
AFAIK the 'rear orange sway bar' will be an aftermarket item, probably K-Mac.
The first full-sized Holden with a factory rear sway bar was the HZ.
Dr Terry.
#4 Posted : Tuesday, 11 September 2007 5:41:03 PM(UTC)
Hi hazzard.
AFAIK the rear orange sway bar will be an aftermarket item, probably K-Mac.
Dr Terry.
81837 Offline
#5 Posted : Tuesday, 11 September 2007 7:10:52 PM(UTC)
81837
You should have four main leaves I think on a GTS, and the "helper" leaf sounds like an aftermarket job.
Guest (5)
