caljktc Offline
#1 Posted : Tuesday, 11 September 2007 6:48:56 PM(UTC)
caljktc
Hello all!
Wondering if any of you may be able to help. I am in the process of restoring an 1971 XW Falcon 500 Wagon and was recently given a Cleveland V8 as a gift for my birthday.
I am unsure if the motor is a 351 or a 302 and have been unable to decifer the block numbers with info i have found on the net.
I beleive the motor has come from a 1977 XC but not overly sure as the coding is a little confusing given the lack of information so i am really making an assumption.
The stamped number reads JG35TD 65533K and the block number reads D2AE CA0 there is also another number directly below which reads 7G5.
Lucy
#2 Posted : Tuesday, 11 September 2007 9:18:30 PM(UTC)
Hello Lucy,
The easiest way to tell whether you have a 302 or 351 is by pulling out one of your spark plugs (or all if you want it easier to turn). Have someone feed a bit of coat hanger type wire straight down the hole onto the piston whilst you turn
Paul351xb Offline
#3 Posted : Wednesday, 12 September 2007 1:19:36 AM(UTC)
Paul351xb
Yep XC Fairmont wagon your motor is out of. As Jim says put some wire down the spark plug hole or take the sump off and have a look at the crank. The crank will have either 351 or 302 stamped into it. Might pay to rip the sump off and have a look at th
caljktc Offline
#4 Posted : Friday, 14 September 2007 7:42:52 PM(UTC)
caljktc
Thanks for the info guys. Will be doing full recon before it is put into the vehicle.
Cheers!
Lucy
caljktc Offline
#5 Posted : Sunday, 30 September 2007 7:44:28 PM(UTC)
caljktc
Hey Guys.
Can you tell the difference between a 2v and 4v cleaveland 302?
Paul351xb Offline
#6 Posted : Monday, 1 October 2007 2:56:30 PM(UTC)
Paul351xb
yeah, the 302 doesn't have 4V heads. Some 302s have a 4 barrel carby, which is where the misunderstanding comes from. 4 venturies is 4V on some 302 compliance plates.
This page was generated in 0.136 seconds.
