Fastlane
Holden Forums
Holden General Discussion
Oil sensor chev 2 parts to plug wire??? Pic
Hi Hope this pic link works its my 350 chev . The oil sensor has a top part like a can and a bottom part that you can plug a wire into. Im just using the dummy light as factory from the 202 which one would I plug the wire into?? http://img523.imageshack...lsenderofsomesortxm5.jpgIf its not broke it will be soon |
Hi keithholen.
What's the question ?
Dr Terry |
Hi keithholen.
Whats the question ?
Dr Terry |
Hi Terry I was wondering where on the metal can thing do I plug my oil pressure gauge. The can has a place to plug wire into and below the metal can is another place to plug a wire into.. I only have the oil pressure light on the dash of my hq.Cheers
I |
Hi keithholden.
There appears to be two senders in the picture. The top one is probably a sensor to drive an aftermarket gauge of some type.
The lower one looks to be a normal oil pressure switch to operate an oil light. Attach your wire to the lowe |
Deifnately looks like 2 senders. Looks like it has been "T"ed and right angles from the port behind the inlet manifold. The "can" matches the appearance of the gauge sender I have, and i recognise the style of the smaller sender from the old HQ I had wi |
__________________________________________ Keep the shiny side up, and the greasy side down. |
Great thanks for that ive now connected the bottom one to my oil light :).
One more thing from my list.
Fastlane
Holden Forums
