#1 Posted : Wednesday, 12 September 2007 8:45:30 AM(UTC)
Hi,
Does the base model HK Monaro have a Monaro badge on each front guard?
The vehicle has a Monaro badge on the drivers guard above the engine capacity badge and this guard has a round drain hole.
The left guard has the engine capacity badge only with no drillings for a Monaro badge. This one has a square drain hole.
I am assuming the vehicle has had a left replacement panel fitted and due to it having the engine badge only, this guard may be from a HK Premier or Brougham (earlier/later /different plant), or more likely a HT/HG front guard.
I am sure Warren told me some time ago that the car should have the badges in the same places as a Kingswood.
Can someone confirm this please as the cars badges looks a bit odd as they are currently.
p.s. my literature shows pictures of base models with a Monaro badge on each front guard however I do have a picture of one vehicle with the engine badge only.
#2 Posted : Wednesday, 12 September 2007 5:29:16 PM(UTC)
Yes you should have engine size under style line and Monaro badge above style line.
LH guard has been replaced, you might find thet the car was in an accident and the Moanro badge broke, they may have been no longer available and the panel shop only pu
