Handgunner Offline
#1 Posted : Thursday, 13 September 2007 8:48:08 AM(UTC)
Handgunner
Hi folks, i am buying a VP single spinner Borg Warner 78 diff.308 from a "wagon".. and was wondering if someone can tell me exactly the width of this diff and the width of my HG Panno Banjo diff please? As a comparison....
I want to know what size / width wheels i can run under my guards, and also if the wagon diff is any narrower than the VP sedan or any axle strength differences ?.. i have spent all the night reading the posts and cant seem to pinpoint the real info that i want... i have learned that this diff will be very strong and suitable for my 307 Chev mild requirements and all at a very low cost $120.00 Diff...$70.00 Brackets welded....$30.00 donor drive shaft..( already have the turbo 400 shaft and yoke ).. then just my brake booster mod and the cost of the driveshaft cut and reweld/ rebalance / shorten etc...?
I hope that all up it will come in close to $350.00 maximum...?
Its gotta be good value even if i crack $450.00 i think.
And spare parts everywhere for when my 383 380 hp engine goes in..lol ( I wish ) ... thanks to everyone for helping me out ...i love to learn about all of this diff stuff.... even the wreckers dont know what you guys know..thats cool !
Cheers, Anthony.......................
Bang Bang
Bang Bang
adam PERTH Offline
#2 Posted : Thursday, 13 September 2007 8:56:32 AM(UTC)
adam PERTH
VP is 1/2 inch narrower than HQ.
I am sure someone knows the difference between HQ to HG.
Call Jason on 0400602647 and have a chat, i think he has just done the exact same conversion.
he doesn't mind a chat
Don't forget to buy a new BW slip centre fo
adam PERTH Offline
#3 Posted : Thursday, 13 September 2007 8:56:32 AM(UTC)
adam PERTH
he doesnt mind a chat
Dont forget to buy a new BW slip centre for
basketcasebear Offline
#4 Posted : Thursday, 13 September 2007 9:04:04 AM(UTC)
basketcasebear
I think you will have to put it in gunner, only then will you know the wheel size? I am doing the same thing as you, and have had the same imfo help from the fella,s in here,, i still wish to know>> how do you know whether a diff is bent? can you
DOH!!!
#5 Posted : Thursday, 13 September 2007 9:38:49 AM(UTC)
basketcasebear
hey adam,
what is a sip centre, and what are they worth?
are they hard to put in?
thanks
ptpro
DOH!!!
#6 Posted : Thursday, 13 September 2007 11:24:04 AM(UTC)
Mostly you cannot see when a diff housing is bent unless it is real bent. It shows up in abnormal tyre wear and even bearing/seal problems. A good wheel aligner should be able to pick up a bent diff housing in a 4 wheel alignment.Beyond that it is a speci
Edited by user Thursday, 13 September 2007 11:25:21 AM(UTC)  | Reason: Not specified
#7 Posted : Thursday, 13 September 2007 4:18:54 PM(UTC)
VB-VK 10-bolt is just narrower than a HG (about an inch), so the VP one will be just wider (probably about an inch). However I dont have any exact measurements. Ive looked at this before and remember the rough sums.
Youll have to make sure you get the
#8 Posted : Thursday, 13 September 2007 4:18:54 PM(UTC)
VB-VK 10-bolt is just narrower than a HG (about an inch), so the VP one will be just wider (probably about an inch). However I don't have any exact measurements. I've looked at this before and remember the rough sums.
You'll have to make sure you get t
#9 Posted : Friday, 14 September 2007 5:45:04 AM(UTC)
basketcasebear
Bugger!!! Byron!!!
we have to straighten the axles after welding?
does this cost much?
is it a big prob with the axles, after welding? or is it just to make sure?
ptpro
DOH!!!
Fred Offline
#10 Posted : Sunday, 16 September 2007 11:31:47 AM(UTC)
Fred
We fitted a VP Commodore diff under the rear end of a HQ Holden ute, the brakes took a bit of doing but with the help of the guys here we were put on the right track.We also used the VP Commodore front disc mounted to HQ disc brake stubs.
God is Dog sp
#11 Posted : Monday, 17 September 2007 2:57:16 AM(UTC)
Just ask any quality diff conversion place. AFAIK the axle tubes bend like bananas when welded.
